Mathematical study of very high voltage power networks I: The optimal DC power flow problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
J. Frederic Bonnans
  • Fonction : Auteur
  • PersonId : 833418
  • IdHAL : bonnans
The optimal power flow problem consists in setting the voltage and power delivered at the nodes of an electrical network, in order to minimize the loss of power over the lines. This paper is the first of a series dedicated to the mathematical study of this problem, based on an asymptotic analysis, in which the small parameter is the inverse of the reference voltage of the network. We call this scheme the very high voltage approximation. Here we deal with the case of direct current. We obtain an analytic expansion for the optimal value and the solution.
RR-2408.pdf (248.42 Ko) Télécharger le fichier
inria-00074267 , version 1 (24-05-2006)
  • HAL Id : inria-00074267 , version 1
J. Frederic Bonnans. Mathematical study of very high voltage power networks I: The optimal DC power flow problem. [Research Report] RR-2408, INRIA. 1994. ⟨inria-00074267⟩
117 Consultations
187 Téléchargements
