Adaptive Parameterization using Free-Form Deformation for Aerodynamic Shape Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Parameterization techniques commonly used in aerodynamic shape optimization are essentially general and multi-purpose approaches. As a consequence, they cannot be well suited to a particular shape optimization problem. The present study proposes a new method that adapts an initial and perhaps naïve parameterization of an aerodynamic shape by the Free-Form Deformation (FFD) technique, to the particular optimization problem to solve, according to a first approximation of the solution. This parameterization adaption method is included in a three-dimensional aerodynamic shape optimization procedure for Eulerian flows and is demonstrated for the design optimization of the wing of a business aircraft.
RR-5949.pdf (1.08 Mo) Télécharger le fichier
inria-00085058 , version 1 (11-07-2006)
inria-00085058 , version 2 (18-07-2006)
  • HAL Id : inria-00085058 , version 2
Régis Duvigneau. Adaptive Parameterization using Free-Form Deformation for Aerodynamic Shape Optimization. [Research Report] RR-5949, INRIA. 2006, pp.40. ⟨inria-00085058v2⟩
394 Consultations
726 Téléchargements
