Changing our view on design evaluation meetings methodology: a study of software technical review meetings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Design Studies Année : 2004
By contrast to design meetings, design evaluation meetings (DEMs) have generally been considered as situations in which, according to DEMs methodologies, design activities are quite marginal. In a study of DEMs in software development, i.e. in technical review meetings following a particular review methodology, we showed: (i) the occurrence of design activities as part of an argumentation process; (ii) the relative importance of cognitive synchronisation as a prerequisite for evaluation; (iii) the important role played in evaluation by argumentation that makes explicit the underlying design rationale (DR). On the basis of our results, we discuss the potential for using DR methodologies in this kind of meetings.
Paper8.pdf (533.86 Ko) Télécharger le fichier
inria-00117060 , version 1 (29-11-2006)
inria-00117060 , version 2 (31-01-2007)
Patrick d'Astous, Françoise Détienne, Willemien Visser, Pierre Robillard. Changing our view on design evaluation meetings methodology: a study of software technical review meetings. Design Studies, 2004, 25. ⟨inria-00117060v1⟩
126 Consultations
201 Téléchargements
