HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Non Rigid Registration of Diffusion Tensor Images
Olivier Faugeras 1 Christophe Lenglet 2, * Théodore Papadopoulo 1 Rachid Deriche 1
* Corresponding author
1 ODYSSEE - Computer and biological vision
DI-ENS - Département d'informatique - ENS Paris, CRISAM - Inria Sophia Antipolis - Méditerranée , ENS-PSL - École normale supérieure - Paris, Inria Paris-Rocquencourt, ENPC - École des Ponts ParisTech
Abstract : We propose a novel variational framework for the dense non-rigid registration of Diffusion Tensor Images (DTI). Our approach relies on the differential geometrical properties of the Riemannian manifold of multivariate normal distributions endowed with the metric derived from the Fisher information matrix. The availability of closed form expressions for the geodesics and the Christoffel symbols allows us to define statistical quantities and to perform the parallel transport of tangent vectors in this space. We propose a matching energy that aims to minimize the difference in the local statistical content (means and covariance matrices) of two DT images through a gradient descent procedure. The result of the algorithm is a dense vector field that can be used to wrap the source image into the target image. This article is essentially a mathematical study of the registration problem. Some numerical experiments are provided as a proof of concept.
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/inria-00125876
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, January 23, 2007 - 11:48:50 AM
Last modification on : Thursday, March 17, 2022 - 10:08:33 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 11:44:34 AM
RR-6104.pdf
Identifiers
  • HAL Id : inria-00125876, version 2
Citation
Olivier Faugeras, Christophe Lenglet, Théodore Papadopoulo, Rachid Deriche. Non Rigid Registration of Diffusion Tensor Images. [Research Report] RR-6104, INRIA. 2007, pp.39. ⟨inria-00125876v2⟩
Share
Metrics
Record views
270
Files downloads
139
