Robust sampled-data stabilization of linear systems - An input delay approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2004
A new approach to robust sampled-data control is introduced. The system is modelled as a continuous-time one, where the control input has a piecewise-continuous delay. Sufficient linear matrix inequalities (LMIs) conditions for sampled-data state-feedback stabilization of such systems are derived via descriptor approach to time-delay systems. The only restriction on the sampling is that the distance between the sequel sampling times is not greater than some prechosen h>0 for which the LMIs are feasible. For h → 0 the conditions coincide with the necessary and sufficient conditions for continuous-time state-feedback stabilization. Our approach is applied to two problems: to sampled-data stabilization of systems with polytopic type uncertainities and to regional stabilization by sampled-data saturated state-feedback.
Fridman_Auto04_Delay_sampling.pdf (141.29 Ko) Télécharger le fichier
inria-00131031 , version 1 (28-11-2007)
  • HAL Id : inria-00131031 , version 1
Emilia Fridman, Alexandre Seuret, Jean-Pierre Richard. Robust sampled-data stabilization of linear systems - An input delay approach. Automatica, 2004. ⟨inria-00131031⟩
414 Consultations
2253 Téléchargements
