Reports
Reduced-Basis approach for homogenization beyond the periodic setting
Sébastien Boyaval 1
1 MICMAC - Methods and engineering of multiscale computing from atom to continuum
Inria Paris-Rocquencourt, ENPC - École des Ponts ParisTech
Abstract : We consider the computation of averaged coefficients for the homogenization of elliptic partial differential equations. In this problem, like in many multiscale problems, a large number of similar computations parametrized by the macroscopic scale is required at the microscopic scale. This is a framework very much adapted to model order reduction attempts. The purpose of this work is to show how the reduced-basis approach allows to speed up the computation of a large number of cell problems without any loss of precision. The essential components of this reduced-basis approach are the {\it a posteriori} error estimation, which provides sharp error bounds for the outputs of interest, and an approximation process divided into offline and online stages, which decouples the generation of the approximation space and its use for Galerkin projections.
Document type :
Reports
Complete list of metadatas
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00132763
Contributor : Rapport de Recherche Inria <>
Submitted on : Monday, February 26, 2007 - 10:17:42 AM
Last modification on : Friday, May 25, 2018 - 12:02:03 PM
Long-term archiving on: : Thursday, September 23, 2010 - 4:43:46 PM
RR-6130.pdf
Identifiers
Collections
Citation
Sébastien Boyaval. Reduced-Basis approach for homogenization beyond the periodic setting. [Research Report] RR-6130, INRIA. 2007, pp.29. ⟨inria-00132763v3⟩
Share
Metrics
Record views
263
Files downloads
286
