Policy iteration algorithm for zero-sum stochastic games with mean payoff - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2006
We give a policy iteration algorithm to solve zero-sum stochastic games with finite state and action spaces and perfect information, when the value is defined in terms of the mean payoff per turn. This algorithm does not require any irreducibility assumption on the Markov chains determined by the strategies of the players. It is based on a discrete nonlinear analogue of the notion of reduction of a super-harmonic function.
CRASPreprint.pdf (108.81 Ko) Télécharger le fichier
inria-00144146 , version 1 (01-05-2007)
Jean Cochet-Terrasson, Stéphane Gaubert. Policy iteration algorithm for zero-sum stochastic games with mean payoff. Comptes Rendus. Mathématique, 2006, 343 (5), pp.377-382. ⟨10.1016/j.crma.2006.07.011⟩. ⟨inria-00144146⟩
157 Consultations
350 Téléchargements
