Maximum Entropy Distribution with Constrained Mean - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
This note presents the derivation of the maximum entropy distribution of a real variable on the unit segment, when its first moment is constrained. The functional form of the resulting distribution is an exponential with two Lagrange multipliers. We show that there is unique solution for those multipliers. However this solution has to be numerically approximated. As a special case, we find the uniform distribution when the constrained mean is centered.
distrib_max_ent.pdf (145.04 Ko) Télécharger le fichier
inria-00167289 , version 1 (17-08-2007)
inria-00167289 , version 2 (05-09-2007)
  • HAL Id : inria-00167289 , version 1
Pierre Dangauthier. Maximum Entropy Distribution with Constrained Mean. 2007. ⟨inria-00167289v1⟩
100 Consultations
131 Téléchargements
