Gaspard2 UML profile documentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
This document describes the current UML profile of Gaspard2. This profile extends the UML semantics to allow the user to describe a SoC (System-on-Chip) in three steps: the application (behavior of the Soc), the hardware architecture, and the association of the application to the hardware architecture. The application is represented following a data flow model, but additional mechanisms permit the usage of control flow on those applications. In addition to those notions, the profile contains a package introducing factorization mechanisms to enable the compact description of massively parallel and repetitive systems.
gaspard-profile.pdf (1.1 Mo) Télécharger le fichier
inria-00171137 , version 1 (11-09-2007)
inria-00171137 , version 2 (12-09-2007)
  • HAL Id : inria-00171137 , version 2
Rabie Ben Atitallah, Pierre Boulet, Arnaud Cuccuru, Jean-Luc Dekeyser, Antoine Honoré, et al.. Gaspard2 UML profile documentation. [Technical Report] RT-0342, INRIA. 2007, pp.45. ⟨inria-00171137v2⟩
631 Consultations
402 Téléchargements
