An algebraic framework for the design of nonlinear observers with unknown inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The observability properties of nonlinear systems with unknown inputs are characterized via differentially algebraic techniques. State variables and unknown inputs are estimated thanks to a new algebraic numerical differentiator. It is shown through an academic example and a concrete case study that the proposed scheme can be applied to systems that fail to fulfill some usual structural assumptions.
CDC-07.pdf (1.04 Mo) Télécharger le fichier
inria-00172366 , version 1 (15-09-2007)
  • HAL Id : inria-00172366 , version 1
Jean-Pierre Barbot, Michel Fliess, Thierry Floquet. An algebraic framework for the design of nonlinear observers with unknown inputs. 46th IEEE Conference on Decision and Control, 2007, New Orleans, United States. ⟨inria-00172366⟩
12144 Consultations
1239 Téléchargements
