Some 2.5D Models for the Primitive Equations of the Ocean and the Atmosphere - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Analysis and Applications Année : 2007
The primitive equations (PEs) of the atmosphere and the ocean without viscosity are considered. A 2.5D model is introduced, whose motivation is described in the Introduction. A set of nonlocal boundary conditions is proposed, and well-posedness is established for the flows linearized around a constant velocity stratified flow; homogeneous and nonhomogeneous boundary conditions are considered. A related model of dimension 2.5, of physical interest but with fewer degrees of freedom, is also considered at the end.
CLRTT07.pdf (289.83 Ko) Télécharger le fichier
inria-00172578 , version 1 (17-09-2007)
Qingshan Chen, Jacques Laminie, Antoine Rousseau, Roger M. Temam, Joe Tribbia. Some 2.5D Models for the Primitive Equations of the Ocean and the Atmosphere. Analysis and Applications, 2007, 5 (3), pp.199-229. ⟨10.1142/S021953050700095X⟩. ⟨inria-00172578⟩
236 Consultations
205 Téléchargements
