Voltage-stepping schemes for the simulation of spiking neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
The numerical simulation of spiking neural networks requires particular attention. On the one hand, time-stepping methods are generic but theyhardly reproduce accurately the short-time scale uctuations of spiking neurons and need specific treatments to avoid the errors associated with the dis-continuities of ntegrate-and-fire models. On the other hand, event-driven methods are exact but restricted to a limited class of models. We present here a oltage-stepping scheme that combines the advantages of these two approaches and consists of a discretization of the voltage state-space. The numerical simulation is reduced to a local event-driven method that induces an implicit activity-dependent time-stepping scheme: long time-steps are used when the neuron is slowly varying whereas small time-steps are used in periods of intense activity. Our method accurately approximates the neuronal dynamics and we show analytically that such a scheme leads to an high-order algorithm. We illustrate the voltage-stepping method on nonlinear integrate-and-fire models. In this situation, our method consists of an approximation of the original model by a voltage-dependent integrate-and-fire. We compare our method with time-stepping schemes of Runge-Kutta type.
voltstep.pdf (175.22 Ko) Télécharger le fichier
inria-00189386 , version 1 (20-11-2007)
inria-00189386 , version 2 (21-11-2007)
inria-00189386 , version 3 (21-11-2007)
inria-00189386 , version 4 (11-06-2009)
  • HAL Id : inria-00189386 , version 2
Gang Zheng, Arnaud Tonnelier, Dominique Martinez. Voltage-stepping schemes for the simulation of spiking neural networks. 2007. ⟨inria-00189386v2⟩
190 Consultations
411 Téléchargements
