Realistic wireless network model with explicit capacity evaluation - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2008
Philippe Jacquet
We consider a realistic model of wireless network where nodes are di\ spatched in an infinite map with uniform distribution. Signal decays with distance according to attenuation factor $\alpha$. At any time we assume that the distribution of emitters is $\lambda$ per square unit area. From the explicit formula of the laplace transform of received signal we derive the explicit formula for the info\ rmation rate received by a random node which is $\frac{\alpha}{2}(\log 2)^{-1}$ per Hertz. We generalize to any-dimension network maps.
RR-6407.pdf (440.15 Ko) Télécharger le fichier
Dates and versions
inria-00203339 , version 1 (09-01-2008)
inria-00203339 , version 2 (11-01-2008)
inria-00203339 , version 3 (24-01-2008)
Identifiers
  • HAL Id : inria-00203339 , version 2
Cite
Philippe Jacquet. Realistic wireless network model with explicit capacity evaluation. [Research Report] RR-6407, 2008, pp.16. ⟨inria-00203339v2⟩
Collections
INRIA-RRRT
141 View
144 Download
Share
