Realistic wireless network model with explicit capacity evaluation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Philippe Jacquet
We consider a realistic model of wireless network where nodes are di\ spatched in an infinite map with uniform distribution. Signal decays with distance according to attenuation factor $\alpha$. At any time we assume that the distribution of emitters is $\lambda$ per square unit area. From the explicit formula of the laplace transform of received signal we derive the explicit formula for the info\ rmation rate received by a random node which is $\frac{\alpha}{2}(\log 2)^{-1}$ per Hertz. We generalize to any-dimension network maps.
capacity-RR.pdf (437.07 Ko) Télécharger le fichier
inria-00203339 , version 1 (09-01-2008)
inria-00203339 , version 2 (11-01-2008)
inria-00203339 , version 3 (24-01-2008)
  • HAL Id : inria-00203339 , version 3
Philippe Jacquet. Realistic wireless network model with explicit capacity evaluation. [Research Report] RR-6407, INRIA. 2008, pp.16. ⟨inria-00203339v3⟩
151 Consultations
152 Téléchargements
