Modeling fractures as interfaces: a model for Forchheimer fractures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this paper we are concerned with modeling single phase flow in a medium with known fractures. In particular we are interested in the case in which the flow rate in the fractures is large enough to make it appropriate to use Forchheimer's law for modeling the flow in the fractures even though the flow in the surrounding domain is such that Darcy's law is adequate. We describe a model in which the fractures are treated as interfaces. We also consider the case of intersecting fractures and the case of nonconforming meshes.
RR-6419.pdf (781.84 Ko) Télécharger le fichier
inria-00207993 , version 1 (18-01-2008)
inria-00207993 , version 2 (21-01-2008)
  • HAL Id : inria-00207993 , version 2
Najla Frih, Jean E. Roberts, Ali Saada. Modeling fractures as interfaces: a model for Forchheimer fractures. [Research Report] RR-6419, INRIA. 2008, pp.26. ⟨inria-00207993v2⟩
238 Consultations
421 Téléchargements
