Lower bounds for evolution strategies using VC-dimension - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We derive lower bounds for comparison-based or selection-based algorithms, improving existing results in the continuous setting, and extending them to non-trivial results in the discrete case. We introduce for that the use of the VC-dimension of the level sets of the fitness functions; results are then obtained through the use of Sauer's lemma. In the special case of optmization of the sphere function, improved lower bounds are obtained by bounding the possible number of sign conditions realized by some systems of equations. The results include several applications to the parametrization of sequential or parallel algorithms of type $\mul$-ES.
paralb.pdf (190.22 Ko) Télécharger le fichier
inria-00287845 , version 1 (13-06-2008)
  • HAL Id : inria-00287845 , version 1
Olivier Teytaud, Hervé Fournier. Lower bounds for evolution strategies using VC-dimension. Parallel Problem Solving from Nature, Sep 2008, Dortmund, Germany. 10 p. ⟨inria-00287845⟩
374 Consultations
262 Téléchargements
