An error analysis in the algebraic estimation of a noisy sinusoidal signal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The classic example of a noisy sinusoidal signal permits for the first time to derive an error analysis for a new algebraic and non-asymptotic estimation technique. This approach yields a selection of suitable parameters in the estimation procedure, in order to minimize the noise corruption.
FinalV3.pdf (200.3 Ko) Télécharger le fichier
inria-00300234 , version 1 (17-07-2008)
  • HAL Id : inria-00300234 , version 1
Da-Yan Liu, Olivier Gibaru, Wilfrid Perruquetti, Michel Fliess, Mamadou Mboup. An error analysis in the algebraic estimation of a noisy sinusoidal signal. 16th Mediterranean Conference on Control and Automation, Jun 2008, Ajaccio, France. ⟨inria-00300234⟩
405 Consultations
220 Téléchargements
