Fluid-Structure Interaction and multi-body contact. Application to the aortic valves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We present a partitioned procedure for fluid-structure interaction problems in which contacts among different deformable bodies can occur. A typical situation is the movement of a thin valve (e.g. the aortic valve) immersed in an incompressible viscous fluid (e.g. the blood). In the proposed strategy the fluid and structure solvers are considered as independent ``black-boxes'' that exchange forces and displacements; the structure solvers are moreover not supposed to manage contact by themselves. The hypothesis of non-penetration among solid objects defines a non-convex optimization problem. To solve the latter, we use an internal approximation algorithm that is able to directly handle the cases of thin structures and self-contacts. A numerical simulation on an idealized aortic valve is finally realized with the aim of illustrating the proposed scheme.
RR-6583.pdf (2.24 Mo) Télécharger le fichier
inria-00300770 , version 1 (19-07-2008)
  • HAL Id : inria-00300770 , version 1
Matteo Astorino, Jean-Frédéric Gerbeau, Olivier Pantz, Karim-Frédéric Traore. Fluid-Structure Interaction and multi-body contact. Application to the aortic valves. [Research Report] RR-6583, INRIA. 2008, pp.23. ⟨inria-00300770⟩
506 Consultations
1396 Téléchargements
