Diagnosis of Pushdown Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Diagnosis problems of discrete-event systems consist in detecting unobservable defects during system execution. For finite-state systems, the theory is well understood and a number of effective solutions have been developed. For infinite-state systems, however, there are only few results, mostly identifying classes where the problem is undecidable. We consider higher-order pushdown systems and investigate two basic variants of diagnosis problems: the diagnosability, which consists in deciding whether defects can be detected within a finite delay, and the bounded-latency problem, which consists in determining a bound for the delay of detecting defects. We establish that the diagnosability problem is decidable for arbitrary sub-classes of higher-order visibly pushdown systems provided unobservable events leave the stacks unchanged. For this case, we present an effective algorithm. Otherwise, we show that diagnosability becomes undecidable already for first-order visibly pushdown automata. Furthermore, we establish that the bounded-latency problem for higher-order pushdown systems is as hard as deciding finiteness of a higher-order pushdown language. This is in contrast with the case of finite-state systems where the problem reduces to diagnosability.
PI-1904.pdf (259.34 Ko) Télécharger le fichier
inria-00337614 , version 1 (07-11-2008)
  • HAL Id : inria-00337614 , version 1
Christophe Morvan, Sophie Pinchinat. Diagnosis of Pushdown Systems. [Research Report] PI 1904, 2008, pp.19. ⟨inria-00337614⟩
103 Consultations
200 Téléchargements
