Adding expert knowledge and exploration in Monte-Carlo Tree Search - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present a new exploration term, more efficient than clas- sical UCT-like exploration terms and combining efficiently expert rules, patterns extracted from datasets, All-Moves-As-First values and classi- cal online values. As this improved bandit formula does not solve several important situations (semeais, nakade) in computer Go, we present three other important improvements which are central in the recent progress of our program MoGo: { We show an expert-based improvement of Monte-Carlo simulations for nakade situations; we also emphasize some limitations of this modification. { We show a technique which preserves diversity in the Monte-Carlo simulation, which greatly improves the results in 19x19. { Whereas the UCB-based exploration term is not efficient in MoGo, we show a new exploration term which is highly efficient in MoGo. MoGo recently won a game with handicap 7 against a 9Dan Pro player, Zhou JunXun, winner of the LG Cup 2007, and a game with handicap 6 against a 1Dan pro player, Li-Chen Chien.
peacg.pdf (388.17 Ko) Télécharger le fichier
inria-00386477 , version 1 (21-05-2009)
  • HAL Id : inria-00386477 , version 1
Guillaume Chaslot, Christophe Fiter, Jean-Baptiste Hoock, Arpad Rimmel, Olivier Teytaud. Adding expert knowledge and exploration in Monte-Carlo Tree Search. Advances in Computer Games, 2009, Pamplona, Spain. ⟨inria-00386477⟩
294 Consultations
947 Téléchargements
