On a Direct Study of an Operator Riccati Equation Appearing in Boundary Value Problems Factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematical Sciences Année : 2008
Nadra Bouarroudj
  • Fonction : Auteur
  • PersonId : 860597
Bento Louro
  • Fonction : Auteur
  • PersonId : 860598
Maria Orey
  • Fonction : Auteur
  • PersonId : 860599
In this paper we propose a direct study of the Riccati equation satisfied by the Dirichlet-Neumann operator defined on a moving section for an elliptic boundary value problem set in a cylindrical domain [3]. Similar equations are studied in control theory. The additional difficulty of this problem is due to the unboundedness of the right-hand side and of the solution of the equation. The Yosida regularization is used to overcome it.
Fichier non déposé
inria-00387563 , version 1 (25-05-2009)
  • HAL Id : inria-00387563 , version 1
Nadra Bouarroudj, Jacques Henry, Bento Louro, Maria Orey. On a Direct Study of an Operator Riccati Equation Appearing in Boundary Value Problems Factorization. Applied Mathematical Sciences, 2008, 2 (46), pp.2247 - 2257. ⟨inria-00387563⟩
82 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
