Results on hypergraph planarity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2004
Using the notion of planarity and drawing for hypergraphs introduced respectively by Johnson and Pollak [JP87] and Mäkinen [Ma90], we show in this paper that any hypergraph having less than nine hyperedges is vertex-planar and can be drawn in the edge standard and in the subset standard without edge crossing.
hypergraphplanarity.pdf (246.19 Ko) Télécharger le fichier
inria-00389591 , version 1 (29-05-2009)
  • HAL Id : inria-00389591 , version 1
Anne Verroust-Blondet, Marie-Luce Viaud. Results on hypergraph planarity. 2004. ⟨inria-00389591⟩
88 Consultations
195 Téléchargements
