Optimization of Industrial Applications with Hardware in the Loop - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper deals with optimizing the task cycle time of industrial robots integrated in complex robot cells. Trajectory optimizers are usually based on models and can't properly deal with uncertainties due to interactions between the robot and its environment. We propose here a trajectory optimizer with hardware in the loop which can take into account constraints such as maximum authorized temperature and maximum authorized torque. Our approach is based on unconstrained optimization algorithms without derivatives and penalty methods. Experiments on real industrial applications showed good robustness properties of this algorithm even with a high number of parameters and with changes of the robot task.
Global.pdf (137.83 Ko) Télécharger le fichier
inria-00390451 , version 1 (02-06-2009)
  • HAL Id : inria-00390451 , version 1
Matthieu Guilbert, Pierre-Brice Wieber, Luc Joly. Optimization of Industrial Applications with Hardware in the Loop. IEEE-RSJ International Conference on Intelligent Robots & Systems, 2006, Beijing, China. ⟨inria-00390451⟩
195 Consultations
260 Téléchargements
