A note on cycle covering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
This study considers the design of a survivable WDM network based on covering the initial network with sub-networks, which are protected independently from each other.
art2spaa.pdf (68.08 Ko) Télécharger le fichier
inria-00429182 , version 1 (01-11-2009)
Jean-Claude Bermond, David Coudert, Lilian Chacon, Francois Tillerot. A note on cycle covering. ACM Symposium on Parallel Algorithms and Architectures (SPAA), 2001, Hersonissos, Greece. pp.310-311, ⟨10.1145/378580.378716⟩. ⟨inria-00429182⟩
216 Consultations
224 Téléchargements
