Qualitative control of periodic solutions in piecewise affine systems; application to genetic networks
Etienne Farcot 1, * Jean-Luc Gouzé 2
* Auteur correspondant
1 VIRTUAL PLANTS - Modeling plant morphogenesis at different scales, from genes to phenotype
CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique, Centre de coopération internationale en recherche agronomique pour le développement [CIRAD] : UMR51
2 COMORE - Modeling and control of renewable resources
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Hybrid systems, and especially piecewise affine (PWA) systems, are often used to model gene regulatory networks. In this paper we elaborate on previous work about control problems for this class of models, using also some recent results guaranteeing the existence and uniqueness of limit cycles, based solely on a discrete abstraction of the system and its interaction structure. Our aim is to control the transition graph of the PWA system to obtain an oscillatory behaviour, which is indeed of primary functional importance in numerous biological networks; we show how it is possible to control the appearance or disappearance of a unique stable limit cycle by hybrid qualitative action on the degradation rates of the PWA system, both by static and dynamic feedback, i.e. the adequate coupling of a controlling subnetwork. This is illustrated on two classical gene network modules, having the structure of mixed feedback loops.
Liste complète des métadonnées
Littérature citée [30 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00437928
Contributeur : Etienne Farcot <>
Soumis le : mardi 1 décembre 2009 - 17:50:44
Dernière modification le : mardi 29 mai 2018 - 12:50:49
Document(s) archivé(s) le : jeudi 17 juin 2010 - 23:00:13
Fichiers
RR-7130.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00437928, version 1
  • ARXIV : 0912.0440
Collections
Citation
Etienne Farcot, Jean-Luc Gouzé. Qualitative control of periodic solutions in piecewise affine systems; application to genetic networks. RR-7130. 2009. 〈inria-00437928〉
Métriques
Consultations de la notice
752
Téléchargements de fichiers
190
