Accurate image search using the contextual dissimilarity measure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2010
Hervé Jégou
  • Fonction : Auteur
  • PersonId : 833473
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
Hedi Harzallah
  • Fonction : Auteur
  • PersonId : 861132
Jakob Verbeek
This paper introduces the contextual dissimilarity measure which significantly improves the accuracy of bag-of-features based image search. Our measure takes into account the local distribution of the vectors and iteratively estimates distance update terms in the spirit of Sinkhorn's scaling algorithm, thereby modifying the neighborhood structure. Experimental results show that our approach gives significantly better results than a standard distance and outperforms the state-of-the-art in terms of accuracy on the Nister-Stewenius and Lola datasets. This paper also evaluates the impact of a large number of parameters, including the number of descriptors, the clustering method, the visual vocabulary size and the distance measure. The optimal parameter choice is shown to be quite context dependent. In particular using a large number of descriptors is interesting only when using our dissimilarity measure. We have also evaluated two novel variants, multiple assignment and rank aggregation. They are shown to further improve accuracy, at the cost of higher memory usage and lower efficiency.
jegou_cdm.pdf (7.39 Mo) Télécharger le fichier
Format : Figure, Image
inria-00439311 , version 1 (25-01-2011)
inria-00439311 , version 2 (16-02-2011)
inria-00439311 , version 3 (15-03-2011)
Hervé Jégou, Cordelia Schmid, Hedi Harzallah, Jakob Verbeek. Accurate image search using the contextual dissimilarity measure. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2010, 32 (1), pp.2--11. ⟨10.1109/TPAMI.2008.285⟩. ⟨inria-00439311v2⟩
679 Consultations
1568 Téléchargements
