Enabling Connectors in Hierarchical Component Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
The continual growth of computing and storage capabilities nable numerical applications to integrate more and more phenomena in their computations at the price of increased complexity. Hierarchical component models appear as an interesting approach to handle such complexity. However defining and implementing efficient interactions between hierarchical components is a difficult task, especially in the case of parallel and distributed applications. Connectors from Architecture Description Languages (ADL) are a promising solution to this problem. However, they have only been introduced in flat component models. This paper describes Hlcm, a model supporting both connectors and component hierarchy. This is achieved by describing potential interaction of components using the new concept of open connections. Complex interactions such as data sharing and parallel interactions are successfully supported by Hlcm. An implementation, based on model transformation and on CCM, illustrates its feasibility and benefits.
RR-7204.pdf (337.08 Ko) Télécharger le fichier
inria-00456608 , version 1 (15-02-2010)
inria-00456608 , version 2 (17-02-2010)
inria-00456608 , version 3 (25-08-2010)
  • HAL Id : inria-00456608 , version 2
Julien Bigot, Christian Pérez. Enabling Connectors in Hierarchical Component Models. [Research Report] RR-7204, 2010. ⟨inria-00456608v2⟩
Collections
INRIA-RRRT
195 Consultations
306 Téléchargements
