New interface
Reports (Research report)
Enabling Connectors in Hierarchical Component Models
Julien Bigot 1, * Christian Pérez 1
* Corresponding author
1 GRAAL - Algorithms and Scheduling for Distributed Heterogeneous Platforms
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : The continual growth of computing and storage capabilities enables scientific numerical applications to integrate more and more phenomena in their computations at the price of increased complexity. Hierarchical component models appear as an interesting approach to handle such complexity. However defining and implementing efficient interactions between hierarchical components is a difficult task, especially in the case of parallel and distributed applications. Connectors originating from Architecture Description Languages (ADL) offer a promising solution to this problem. There are however some cases where a simple combination of hierarchy and connectors in a single component model forces users to choose between an efficient implementation of components and their black box behavior. This paper describes HLCM, a model with connectors and hierarchy that provides /open connections/ as a mechanism to describe component interface that enhances encapsulation and eases component implementation replacement while supporting efficient interactions. Complex interactions such as data sharing and parallel method calls are successfully supported by HLCM. An implementation, based on model transformation and on CCM, illustrates its feasibility and benefits.
Document type :
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/inria-00456608
Contributor : Julien Bigot Connect in order to contact the contributor
Submitted on : Wednesday, August 25, 2010 - 3:56:05 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:42 AM
Long-term archiving on: : Thursday, December 1, 2016 - 12:12:41 PM
File
RR-7204.pdf
Identifiers
  • HAL Id : inria-00456608, version 3
Citation
Julien Bigot, Christian Pérez. Enabling Connectors in Hierarchical Component Models. [Research Report] RR-7204, INRIA. 2010. ⟨inria-00456608v3⟩
Share
Metrics
Record views
182
Files downloads
241
