Component based approach using OMNeT++ for Train Communication Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper reports on our experience in using OMNeT++ to develop a network simulator focused on railway environments. Common design problems are analyzed, making emphasis on radio communication models. Scalability issues are raised when modeling the large topologies that are associated with railway communications. Our conclusions point out that model re-usability must be reinforced and that a component-based design must be adopted in order to build a tool for generating valuable performance results.
AADMU09.pdf (193.8 Ko) Télécharger le fichier
inria-00501882 , version 1 (13-07-2010)
  • HAL Id : inria-00501882 , version 1
Juan-Carlos Maureira, Paula Uribe, Olivier Dalle, Jorge Anaya, Takeshi Asahi. Component based approach using OMNeT++ for Train Communication Modeling. ITS-T 2009, INRETS, Oct 2009, Lille., France. ⟨inria-00501882⟩
367 Consultations
416 Téléchargements
