Revisiting LFSMs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Revisiting LFSMs
François Arnault
  • Fonction : Auteur
  • PersonId : 916355
DMI
Thierry Pierre Berger
DMI
Marine Minier
Benjamin Pousse
  • Fonction : Auteur
DMI
Linear Finite State Machines (LFSMs) are particular primitives widely used in information theory, coding theory and cryptography. Among those linear automata, a particular case of study is Linear Feedback Shift Registers (LFSRs) studied and implemented in many cryptographic applications such as design of stream ciphers or pseudo-random generation. LFSRs could be seen as particular LFSMs without inputs. In this paper, we give first a general representation of LFSMs using traditional matrices representation linking this definition together with a new polynomial representation leading to sparse representations and implementations. As direct applications, we focus our work on the LFSRs case and show how the new LFSMs representation leads to a powerful design for LFSRs called Ring LFSRs efficient in both hardware and software. We also study a particular LFSRs subcase called windmill LFSRs used for example in the E0 stream cipher and we generalize their representation leading to better hardware performances.
Mots clés
Fichier non déposé
inria-00524376 , version 1 (07-10-2010)
  • HAL Id : inria-00524376 , version 1
François Arnault, Thierry Pierre Berger, Marine Minier, Benjamin Pousse. Revisiting LFSMs. [Research Report] 2010, pp.15. ⟨inria-00524376⟩
185 Consultations
0 Téléchargements
