Strong Semiclassical Approximation of Wigner Functions for the Hartree Dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
A. Athanassoulis
  • Fonction : Auteur
T. Paul
  • Fonction : Auteur
F. Pezzotti
  • Fonction : Auteur
M. Pulvirenti
  • Fonction : Auteur
We consider the Wigner equation corresponding to a nonlinear Schroedinger evolution of the Hartree type in the semiclassical limit $\hbar\to 0$. Under appropriate assumptions on the initial data and the interaction potential, we show that the Wigner function is close in $L^2$ to its weak limit, the solution of the corresponding Vlasov equation. The strong approximation allows the construction of semiclassical operator-valued observables, approximating their quantum counterparts in Hilbert-Schmidt topology. The proof makes use of a pointwise-positivity manipulation, which seems necessary in working with the $L^2$ norm and the precise form of the nonlinearity. We employ the Husimi function as a pivot between the classical probability density and the Wigner function, which -- as it is well known -- is not pointwise positive in general.
inria-00528983 , version 1 (23-10-2010)
  • HAL Id : inria-00528983 , version 1
  • ARXIV : 1009.0470
A. Athanassoulis, T. Paul, F. Pezzotti, M. Pulvirenti. Strong Semiclassical Approximation of Wigner Functions for the Hartree Dynamics. 2010. ⟨inria-00528983⟩
Collections
CMLS TDS-MACS
18 Consultations
0 Téléchargements
