Random Generation of Positive TAGEDs wrt. the Emptiness Problem
Tree automata are a widely used formalism in Computer Science. Since their creation in the fifties, numerous more expressive extensions have been proposed. Unfortunately, the decision problems associated with these extensions are quite often undecidable or in prohibitive classes of algorithmic complexity (NP-complete or worse), and little work has gone into finding efficient heuristics for them. Beyond the inherent difficulty of those problems, a common hitch in this line of research is the experimental evaluation of new algorithms. As those extensions of tree automata have remained in chiefly theoretical spheres, there are no established testbeds from the "real world" against which to quantify the efficiency (or lack thereof) of new algorithms. Failing that, there is a need to generate suitable testbeds at random. Regrettably, there is little material in the literature regarding random generation of tree automata, and none at all regarding extensions such as Tree Automata with Global Equality and Disequality Constraints (TAGEDs). It should also be noted that what little material there is does not concern itself with the interest of the generated automata wrt. specific decision problems. In this report we present a scheme for random generation of positive TAGEDs, with a focus on making them interesting wrt. the Emptiness problem.
