Error estimates for the logarithmic barrier method in stochastic linear quadratic optimal control problems
We consider a linear quadratic stochastic optimal control problem whith non-negativity control constraints. The latter are penalized with the classical logarithmic barrier. Using a duality argument and the stochastic minimum principle, we provide an error estimate for the solution of the penalized problem which is the natural extension of the well known estimate in the deterministic framework.
Optimisation et contrôle [math.OC]
