New interface
Journal articles
An added-mass free semi-implicit coupling scheme for fluid-structure interaction
Matteo Astorino 1 Franz Chouly 1 Miguel Angel Fernández 1, *
* Corresponding author
1 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : In this note we propose a semi-implicit coupling scheme for the numerical simulation of fluid-structure interaction systems involving a viscous incompressible fluid. The scheme is stable irrespectively of the so-called added-mass effect and allows for conservative time-stepping within the structure. The efficiency of the scheme is based on the explicit splitting of the viscous effects and geometrical/convective non-linearities, through the use of the Chorin-Temam projection scheme within the fluid. Stability relies on the implicit treatment of the pressure stresses and on the Nitsche's treatment of the viscous coupling.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00542751
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Friday, December 3, 2010 - 2:27:03 PM
Last modification on : Friday, January 21, 2022 - 3:16:56 AM
Identifiers
Citation
Matteo Astorino, Franz Chouly, Miguel Angel Fernández. An added-mass free semi-implicit coupling scheme for fluid-structure interaction. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2009, 347 (1-2), ⟨10.1016/j.crma.2008.11.003⟩. ⟨inria-00542751⟩
Share
Metrics
Record views
117
