An added-mass free semi-implicit coupling scheme for fluid-structure interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2009
In this note we propose a semi-implicit coupling scheme for the numerical simulation of fluid-structure interaction systems involving a viscous incompressible fluid. The scheme is stable irrespectively of the so-called added-mass effect and allows for conservative time-stepping within the structure. The efficiency of the scheme is based on the explicit splitting of the viscous effects and geometrical/convective non-linearities, through the use of the Chorin-Temam projection scheme within the fluid. Stability relies on the implicit treatment of the pressure stresses and on the Nitsche's treatment of the viscous coupling.
inria-00542751 , version 1 (03-12-2010)
Matteo Astorino, Franz Chouly, Miguel Angel Fernández. An added-mass free semi-implicit coupling scheme for fluid-structure interaction. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2009, 347 (1-2), ⟨10.1016/j.crma.2008.11.003⟩. ⟨inria-00542751⟩
123 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
