Is a Brownian motion skew? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scandinavian Journal of Statistics Année : 2014
We study the asymptotic behavior of the maximum likelihood estimator corresponding to the observation of a trajectory of a Skew Brownian motion, through a uniform time discretization. We characterize the speed of convergence and the limiting distribution when the step size goes to zero, which in this case are non-classical, under the null hypothesis of the Skew Brownian motion being an usual Brownian motion. This allows to design a test on the skewness parameter. We show that numerical simulations that can be easily performed to estimate the skewness parameter, and provide an application in Biology.
is_a_brownian_skew_final.pdf (1.22 Mo) Télécharger le fichier
inria-00544442 , version 1 (14-12-2010)
inria-00544442 , version 2 (26-02-2013)
inria-00544442 , version 3 (21-05-2013)
inria-00544442 , version 4 (19-07-2013)
Antoine Lejay, Ernesto Mordecki, Soledad Torres. Is a Brownian motion skew?. Scandinavian Journal of Statistics, 2014, 5 (2), pp.346-364. ⟨10.1111/sjos.12033⟩. ⟨inria-00544442v4⟩
325 Consultations
396 Téléchargements
