Is a Brownian motion skew? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We study the asymptotic behavior of the maximum likelihood estimator corresponding to the observation of a trajectory of a Skew Brownian motion, through a uniform time discretization. We characterize the speed of convergence and the limiting distribution when the step size goes to zero, which in this case are non-classical, under the null hypothesis of the Skew Brownian motion being an usual Brownian motion. This allows to design a test on the skewness parameter. We show that numerical simulations that can be easily performed to estimate the skewness parameter, and provide an application in Biology.
is_a_brownian_skew_v4.pdf (1.29 Mo) Télécharger le fichier
inria-00544442 , version 1 (14-12-2010)
inria-00544442 , version 2 (26-02-2013)
inria-00544442 , version 3 (21-05-2013)
inria-00544442 , version 4 (19-07-2013)
  • HAL Id : inria-00544442 , version 2
Antoine Lejay, Ernesto Mordecki, Soledad Torres. Is a Brownian motion skew?. 2013. ⟨inria-00544442v2⟩
331 Consultations
396 Téléchargements
