Tight conditions for consistent variable selection in high dimensional nonparametric regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We address the issue of variable selection in the regression model with very high ambient dimension, \textit{i.e.}, when the number of covariates is very large. The main focus is on the situation where the number of relevant covariates, called intrinsic dimension, is much smaller than the ambient dimension. Without assuming any parametric form of the underlying regression function, we get tight conditions making it possible to consistently estimate the set of relevant variables. These conditions relate the intrinsic dimension to the ambient dimension and to the sample size. The procedure that is provably consistent under these tight conditions is simple and is based on comparing the empirical Fourier coefficients with an appropriately chosen threshold value.
Laetitia_COLT_HAL.pdf (213.64 Ko) Télécharger le fichier
inria-00566721 , version 1 (17-02-2011)
inria-00566721 , version 2 (17-02-2011)
  • HAL Id : inria-00566721 , version 1
Laëtitia Comminges, Arnak S. Dalalyan. Tight conditions for consistent variable selection in high dimensional nonparametric regression. 2011. ⟨inria-00566721v1⟩
181 Consultations
286 Téléchargements
