New interface
Reports (Research report)
An implicit hybridized discontinuous Galerkin method for time-domain Maxwell's equations
Stephane Lanteri 1 Ronan Perrussel 2
1 NACHOS - Numerical modeling and high performance computing for evolution problems in complex domains and heterogeneous media
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
2 LAPLACE-GRE - Groupe de Recherche en Electromagnétisme
LAPLACE - LAboratoire PLasma et Conversion d'Energie
Abstract : Discontinuous Galerkin (DG) methods have been the subject of numerous research activities in the last 15 years and have been successfully developed for various physical contexts modeled by elliptic, mixed hyperbolic-parabolic and hyperbolic systems of PDEs. One major drawback of high order DG methods is their intrinsic cost due to the very large number of globally coupled degrees of freedom as compared to classical high order conforming finite element methods. Different attempts have been made in the recent past to improve this situation and one promising strategy has been recently proposed by Cockburn (Cockburn et al., 2009) in the form of so-called hybridizable DG formulations. The distinctive feature of these methods is that the only globally coupled degrees of freedom are those of an approximation of the solution defined only on the boundaries of the elements of the discretization mesh. The present work is concerned with the study of such a hybridizable DG method for the solution of the system of Maxwell equations. In this preliminary investigation, a hybridizable DG method is proposed for the two-dimensional time-domain Maxwell equations time integrated by an implicit scheme.
Document type :
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/inria-00578488
Contributor : Stéphane Lanteri Connect in order to contact the contributor
Submitted on : Monday, March 28, 2011 - 7:50:09 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:25 AM
Long-term archiving on: : Thursday, March 30, 2017 - 8:45:25 AM
File
RR-7578.pdf
Identifiers
  • HAL Id : inria-00578488, version 3
Citation
Stephane Lanteri, Ronan Perrussel. An implicit hybridized discontinuous Galerkin method for time-domain Maxwell's equations. [Research Report] RR-7578, INRIA. 2011, pp.20. ⟨inria-00578488v3⟩
Share
Metrics
Record views
324
Files downloads
517
