New interface
Reports (Research report)
The planar rocking-block: analysis of kinematic restitution laws, and a new rigid-body impact model with friction
Hongjian Zhang 1 Bernard Brogliato 2
2 BIPOP - Modelling, Simulation, Control and Optimization of Non-Smooth Dynamical Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : In this report we first analyse the capabilities of a generalized kinematic (Newton's like) restitution law for the modeling of a planar rigid block that impacts a rigid ground. The relationships with the classical angular velocity restitution law for rocking motion are examined in detail. Then a new impact law based on the Darboux-Keller's approach with energetic coefficients of restitution (proposed recently in \cite{liu2008a,liu2008b,liu2009a,liu2009b}) and which allows one to incorporate Coulomb's friction, is applied and many cases are studied numerically. The numerical results show that this restitution law is able to reproduce a rich set of block motions with complex energy dispersion effects, that are consistent with everyday life observations. Most importantly it is shown that the kinetic angle between the two unilateral constraints is a parameter that plays a fundamental role in the block's motion, and a critical kinetic angle $\theta_{c}$ is exhibited that allows one to split the blocks into two main classes: slender blocks with a height/width ratio larger than $\theta_{c}$, and flat blocks when the ratio is smaller than $\theta_{c}$. The value of $\theta_{c}$ varies with the friction value. Detailed comparisons with experimental results on free-rocking and with base excitation found in the literature \cite{pena2008,lipscombe1993,elgawadi2010} are proposed and confirm the validity of the proposed model. New results concerning the conditions for the onset or rocking and for the overturning are presented. All the simulations are done with an event-driven algorithm that is available on the INRIA {\sc siconos} open-source software platform.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00579231
Contributor : Bernard Brogliato Connect in order to contact the contributor
Submitted on : Wednesday, March 23, 2011 - 4:09:07 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:02 AM
Long-term archiving on: : Sunday, December 4, 2016 - 12:09:07 AM
File
RockingBlock_Zhang-Brogliato.p...
Identifiers
  • HAL Id : inria-00579231, version 2
Citation
Hongjian Zhang, Bernard Brogliato. The planar rocking-block: analysis of kinematic restitution laws, and a new rigid-body impact model with friction. [Research Report] RR-7580, INRIA. 2011. ⟨inria-00579231v2⟩
Share
Metrics
Record views
420
Files downloads
121
