Numerical analysis of a nickel-iron electrodeposition process. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper deals with a coupled system of non-linear elliptic differential equations arising in electrodeposition modelling process. We show the existence and uniqueness of the solution. A numerical algorithm to compute an approximation of the weak solution is described. We introduce a domain decomposition method to take in account the anisotropy of the solution. We show the domain decomposition method convergence. A numerical example is presented and commented.
inria-00589756 , version 1 (01-05-2011)
Noureddine Alaa, M. Iguernane, Jean Rodolphe Roche. Numerical analysis of a nickel-iron electrodeposition process.. ECMI 2006, 2006, Madrid, Spain. pp.817-821, ⟨10.1007/978-3-540-71992-2_141⟩. ⟨inria-00589756⟩
102 Consultations
0 Téléchargements
