Single row facility layout problem using a permutation-based genetic algorithm
In this paper, a permutation-based genetic algorithm (GA) is applied to the NP-hard problem of arranging a number of facilities on a line with minimum cost, known as the single row facility layout problem (SRFLP). The GA individuals are obtained by using some rule-based as well as random permutations of the facilities, which are then improved towards the optimum by means of specially designed crossover and mutation operators. Such schemes led the GA to handle the SRFLP as an unconstrained optimization problem. In the computational experiments carried out with large-size instances of sizes from 60 to 80, available in the literature, the proposed GA improved several previously known best solutions.
