Algebraic Decoding of Negacyclic Codes over Z4 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Eimear Byrne
  • Fonction : Auteur
  • PersonId : 905246
Marcus Greferath
  • Fonction : Auteur
  • PersonId : 905316
Jens Zumbragel
  • Fonction : Auteur
  • PersonId : 905318
We investigate Berlekamp's negacyclic codes and discover that these codes, when considered over the integers modulo 4, do not su er any of the restrictions on the minimum distance observed in Berlekamp's original papers [2, 3]. We present an algebraic decoding algorithm for this class of codes that corrects any error pattern of Lee weight t. Our treatment uses Grobner bases, the decoding complexity is quadratic in t.
66.pdf (135.13 Ko) Télécharger le fichier
inria-00607733 , version 1 (11-07-2011)
  • HAL Id : inria-00607733 , version 1
Eimear Byrne, Marcus Greferath, Jens Zumbragel, Jaume Pernas. Algebraic Decoding of Negacyclic Codes over Z4. WCC 2011 - Workshop on coding and cryptography, Apr 2011, Paris, France. pp.101-110. ⟨inria-00607733⟩
Collections
WCC2011 TDS-MACS
67 Consultations
178 Téléchargements
