Real-time Visuomotor Update of an Active Binocular Head
Abstract : In order for a binocular head to perform optimal 3D tracking, it should be able to verge its cameras actively, while maintaining geometric calibration. In this work we introduce a calibration update procedure, which allows a robotic head to simultaneously fixate, track, and reconstruct a moving object in real-time. The update method is based on a mapping from motor-based to image-based estimates of the camera orientations, estimated in an offline stage. Following this, a fast online procedure is presented to update the calibration of an active binocular camera pair. The proposed approach is ideal for active vision applications because no image-processing is needed at runtime for the scope of calibrating the system or for maintaining the calibration parameters during camera vergence. We show that this homography-based technique allows an active binocular robot to fixate and track an object, whilst performing 3D reconstruction concurrently in real-time.
Complete list of metadatas
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/inria-00608769
Contributor : Team Perception <>
Submitted on : Tuesday, August 28, 2012 - 10:43:58 AM
Last modification on : Monday, June 17, 2019 - 5:10:05 PM
Long-term archiving on: Thursday, November 29, 2012 - 3:35:33 AM
File
Sapienza-RR.pdf
Identifiers
  • HAL Id : inria-00608769, version 3
Collections
Citation
Michael Sapienza, Miles Hansard, Radu Horaud. Real-time Visuomotor Update of an Active Binocular Head. [Research Report] RR-7682, INRIA. 2012. ⟨inria-00608769v3⟩
Share
Metrics
Record views
475
Files downloads
528
