New interface
Reports (Research report)
Source localization using rational approximation on plane sections
Abstract : In functional neuroimaging, a crucial problem is to localize active sources within the brain non-invasively, from the knowledge of the electromagnetic measurements outside the head. Identification of point sources from boundary measurements is an ill-posed inverse problem. In the case of electroencephalography (EEG), measurements are only available at electrode positions, the number of sources is not known in advance, and the medium within the head is inhomogeneous. This paper presents a new method for EEG source localization, based on rational approximation techniques in the complex plane. The method is used in the context of a nested sphere head model, in combination with a cortical mapping procedure. Results on simulated data prove the applicability of the method in the context of realistic measurements configurations.
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/inria-00613644
Contributor : Théodore Papadopoulo Connect in order to contact the contributor
Submitted on : Tuesday, September 6, 2011 - 4:09:02 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:33 AM
Long-term archiving on: : Monday, December 5, 2016 - 12:20:23 AM
File
RR-7704.pdf
Identifiers
  • HAL Id : inria-00613644, version 2
Citation
Maureen Clerc, Juliette Leblond, Jean-Paul Marmorat, Théodore Papadopoulo. Source localization using rational approximation on plane sections. [Research Report] RR-7704, INRIA. 2011, pp.29. ⟨inria-00613644v2⟩
Share
Metrics
Record views
405
Files downloads
251
