Cardiac Motion Recovery and Boundary Conditions Estimation by Coupling an Electromechanical Model and Cine-MRI Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present a method for cardiac motion recovery using the adjustment of an electromechanical model of the heart to cine MRI. This approach is based on a proactive model which consists in a constrained minimisation of an energy coupling the model and the data. The pre- sented method relies on speci c image features in order to constrain the motion of the endocardia and epicardium and impose boundary condi- tions at the base. Thus, image intensity and gradient information are used to constrain the motion of the myocardium surfaces while a 3D block matching technique leads to the motion estimation of base ver- tices. Finally, we show that the implicit time integration of those forces and personalised boundary conditions lead to a better cardiac motion recovery from cine-MR images.
fimh09-CardiacMotionRecovery.pdf (1.83 Mo) Télécharger le fichier
inria-00616137 , version 1 (08-07-2013)
Florence Billet, Maxime Sermesant, Hervé Delingette, Nicholas Ayache. Cardiac Motion Recovery and Boundary Conditions Estimation by Coupling an Electromechanical Model and Cine-MRI Data. Functional Imaging and Modeling of the Heart 2009 (FIMH'09), 2009, Nice, France. pp.376-385, ⟨10.1007/978-3-642-01932-6_41⟩. ⟨inria-00616137⟩
261 Consultations
184 Téléchargements
