Joint segmentation via patient-specific latent anatomy model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present a generative approach for joint 3D segmentation of patient-speciØc MR scans across diÆerent modalities or time points. The latent anatomy, in the form of spatial parameters, is inferred si- multaneously with the evolution of the segmentations. The individual segmentation of each scan supports the segmentation of the group by sharing common information. The joint segmentation problem is solved via a statistically driven level-set framework. We illustrate the method on an example application of multimodal and longitudinal brain tumor segmentation, reporting promising segmentation results
Fichier non déposé
inria-00616174 , version 1 (19-08-2011)
  • HAL Id : inria-00616174 , version 1
Tammy Riklin-Raviv, Bjoern H. Menze, Koen van Leemput, Bram Stieltjes, Marc-André Weber, et al.. Joint segmentation via patient-specific latent anatomy model. MICCAI Workshop on Probabilistic Methods in Medical Image Analysis (PMMIA'09)), 2009, London, UK, United Kingdom. ⟨inria-00616174⟩
74 Consultations
0 Téléchargements
