Petri Net Reachability Graphs: Decidability Status of FO Properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate the decidability and complexity status of model-checking problems on unlabelled reachability graphs of Petri nets by considering first-order, modal and pattern-based languages without labels on transitions or atomic propositions on markings. We consider several parameters to separate decidable problems from undecidable ones. Not only are we able to provide precise borders and a systematic analysis, but we also demonstrate the robustness of our proof techniques.
DDMM-fsttcs11.pdf (512.59 Ko) Télécharger le fichier
inria-00627657 , version 1 (25-05-2021)
  • HAL Id : inria-00627657 , version 1
Philippe Darondeau, Stephane Demri, Roland Meyer, Christophe Morvan. Petri Net Reachability Graphs: Decidability Status of FO Properties. IARCS Annual Conference on Foundations of Software Technology and Theoretical Computer Science, IARCS, Dec 2011, Bombay, India. ⟨inria-00627657⟩
234 Consultations
47 Téléchargements
