Square Always Exponentiation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christophe Clavier
DMI
Benoit Feix
  • Fonction : Auteur
  • PersonId : 883791
DMI
Georges Gagnerot
  • Fonction : Auteur
  • PersonId : 918159
DMI
Mylène Roussellet
  • Fonction : Auteur
  • PersonId : 883792
Embedded exponentiation techniques have become a key concern for security and efficiency in hardware devices using public key cryptography. An exponentiation is basically a sequence of multiplications and squarings, but this sequence may reveal exponent bits to an attacker on an unprotected implementation. Although this subject has been covered for years, we present in this paper new exponentiation algorithms based on trading multiplications for squarings. Our method circumvents attacks aimed at distinguishing squarings from multiplications at a lower cost than previous techniques. Last but not least, we present new algorithms using two parallel squaring blocks which provide the fastest exponentiation to our knowledge.
square_always.pdf (402.02 Ko) Télécharger le fichier
inria-00633545 , version 1 (18-10-2011)
Christophe Clavier, Benoit Feix, Georges Gagnerot, Mylène Roussellet, Vincent Verneuil. Square Always Exponentiation. 12th International Conference on Cryptology in India - INDOCRYPT 2011, Dec 2011, Chennai, India. pp.40-57, ⟨10.1007/978-3-642-25578-6_5⟩. ⟨inria-00633545⟩
339 Consultations
3141 Téléchargements
