Fractional colorings of cubic graphs with large girth
We show that every (sub)cubic n-vertex graph with sufficiently large girth has fractional chromatic number at most 2.2978, which implies that it contains an independent set of size at least 0.4352n. Our bound on the independence number is valid for random cubic graphs as well, as it improves existing lower bounds on the maximum cut in cubic graphs with large girth.
Mathématique discrète [cs.DM]
